Clio 197 lower ball joint socket size
What socket size do i need to remove the lower ball joint? thanks in advance
I was looking for this the other day, did a search on FB and it seems there isn’t a tool that actually fits, various advice involving heating and smashing with a hammer to purchasing this tool and modifying it..
It’s mentioned in the comments that someone has used it for the 197
Sealey SX027 Lower Ball Joint Socket for Peugeot 405/Citroen, 54mm x 101mm x 142mm https://www.amazon.co.uk/dp/B000RO1U1W/?tag=clio197-21
Reactions: MANAGER
As Liam mentioned above, SX027 works (but needs the teeth filing down slightly to fit)
Welding a nut on is quite popular, as is using stilsons
Better tools than the SX027 are available but are about £100ish every time I've seen them.
Reactions: MANAGER
