Hi all
Ok so went out in my car last night, pretty much all fine! I did notice a bit of hunting at idle when at a set of lights, parked up for the night and when I came back to it later, it kept going into limp home mode with 'injector' & ESP fault showing on the dash, throws it into limp mode, runs on 2 cylinders only! switch off and then on again and it will run fine for a few more miles until it repeats the process!
Checked plugs and coils today, swapped them around etc, outer 2 cylinders are not firing when in limp mode, no codes showing?
Im thinking cam angle sensor breaking down??
Help!
Help!
