Clio 197 fron Spain
Hi guys!
I'm Mori, I've been on the forum for a while, but the time has come to introduce myself, and present my Clio.
It's a Clio RS 197 from 2006
At the moment it has the following modifications:
Engine
•DIY ported and matched inlet
•R3 airbox
•Stock manifold emptyed
• 832 Head
•Full Orbisud x85 cup exhaust
•Ecusport remap (Spain)
Exterior
•17x8 cup wheels
•Front stock cup suspension lowered
•Rear stock cup shocks with Apex springs
•Cup wing
Brakes
•Rc6 front pads
•Oreca GR.N front discs
•Metalic brake lines
•Ds2500 rear pads
•Oem rear discs
20220331_103929.jpg20220331_103256.jpg20220331_103249.jpg20220331_103236.jpg20220131_180259.jpg20211009_092334.jpg244739142_4498489346896780_7633702197375507896_n.jpg245820219_4498487820230266_4976975606259069755_n.jpg245504773_4498494416896273_8329602856226462301_n.jpg
Welcome.
The combination of your R3 intake and exhaust must make an excellent noise when you are driving on track.
Hola Amigo,
Greetings from Galicia, nice car, nice mods. Following your build, and wanting to do the R3 box myself. Whereabouts are you from?
Hola Amigo,
Hello Nardo! I'm from Córdoba
If you are going to make the r3 airbox yourself, I recommend that you reinforce the edges where the filter rests, if it is made of fiberglass it can break as in my case with the RRPROS replica
Hola Nardo! Soy de Córdoba :smile:
Si vas a fabricar tu mismo la campana r3, te recomiendo que refuerces los bordes donde apoya el filtro, si esta hecha de fibra de vidrio puede partirse como en mi caso con la replica de RRPROS
''RRPROS replica ''
Do you have a link to their product? I'm English, living in Spain, collecting those sources, links. Gracias!
''RRPROS replica ''
About 250€ without filter, only the airbox with silicon hose
