CallorFold
Planned to have a go at cleaning the throttle body today - (there's a guide in the How To Section, but it shows Thread cannot be found )
Removed rubber pipe and could see it was quite dirty, however I couldn't open the valve?
Admittedly I only gave it a small prod with my finger as didn't want to do any damage etc.
Should you just be able to press it open so you can clean properly inside?
Do you need to, or is it worth disconnecting the electrical clip?
