Hi all,as some of you may know i've had my 64mm TB on a good while now and it still won't settle so i've come to the conclusion it must have been a slightly faulty unit to start with,i did check it but hey these things happen,anyway as my car has been mapped to suit the 64mm TB i'd like to stick with it so thought about swapping the internals from my original 60mm TB to the 64mm version,my question is,apart from the obviuosly bigger butterfly,is there anything else that will have been changed on the 64mm one? or will i just be able to do a straight swap?
i noticed the other day the 64mm TB makes a buzzing noise when the ignition is on,don't think this is normal so i plugged my original in and turned the ignition on,it still buzzed but very very quietly compared to the 64mm one,so i'm thinking it could be the little motor inside thats causing the issue,
inside the 60mm TB,
inside 60mm TB by scott1532, on Flickr
any help will be greatly appreciated,cheers
sorry forgot to mention,i have spoke to benmc off here and he's willing to show me the ropes when it comes to stripping the units,just wondered if it was possible first before i start,don't want to end up with 2 dicky TB's
inside the 60mm TB,
