Car cut out after flash of esp light now doesnt even crank. Engine fan comes on with ignition and it comes up with low battery warning.
Ive tried boost pack no difference, no click of starter or even sign of crank. I've tried jumping it. No visible dead fuses.
Car is mainly track based and rear is stripped out. Travelling with track wheels loose in back.
Ran great all day at track day.
This is Josh's car so you may have seen similar posts on fb.
Thanks for any help
Are you stuck at the track or side of road if so what tools do you have to hand has the battery been relocated
Na got home by aa. We've had another look and seen to have some brake fluid down by back of pedal. Could it be a brake switch which is now contaminated and won't let it start.
Yea but by pressing the clutch should let it start unless the car needs to feel the electrical resistance of the brake switch pugged in was the track day wet is it a key or keycard, what message is not the display
