Since installing the new stereo the one-touch windows won't reset. I've tried everything. I'm sure they are not moisture affected, as I think they worked flawlessly before installing. Both sides act up the same and won't initialize.
I've tried every procedure there is, including initializing the sunroof as per the workshop instructions, with the engine running and all, before initializing the windows. Nothing. They will only open and close in safe-mode 50mm at a time.
I know there is a difference between the key models, like mine, and the key-card ones.
Has anyone had similar problems? The sunroof is fine which makes me think the computer is fine too. Still something is preventing it from authorizing the one-touch function.
