I’m after the pin-outs for the 197 Camshaft Sensor and Camshaft Solenoid plugs if anyone can help me? I think i have the camshaft sensor pinout sorted (using the attached) but also need the 2 pin solenoid pinout. I believe one is 5v and the other is the sensor wire but does anyone know which way round they need to be wired in?If i’m looking at the photo correctly for the cam sensor pinout, pin 1 is ground, pin 2 is the signal wire and pin 3 is 5v supply.
