Okay need an educated opinion and advice of someone whos worked on renaults before or a good technician.
Basic story i have a re-occuring problem with my car in the shape of BRAKING FAULT on the dash with a very irritating beep. Originally it'd come and stay on for say 30 or 40 miles before going out, but eventually stayed on.
After a couple weeks/300 miles i gave up on it dissapearing and it went to renaults. Fault codes picked up both rear abs sensors faulty, they checked and rechecked and couldnt find a problem with them so deleted the codes and sent me on my way. After brief advice on here i put it down to the car being on the rollers and thinking the two rear sensors were broke as they rear wheels remained stationary when the fronts spun up.
2 problem free months down the line and 10 metres from my garage one morning i get the same fault, took it back to renault and more or less same story, faulty rear sensors, changed this time and sent on my way.
a month later ( yesterday ) 10 metres from my garage once again and you guessed it, braking fault on my dash. Im reluctant to take it to renaults as their quality of work so far is dissapointing.
So to the matter at hand, which could be causing this problem? my garage suffers from quite bad brick dust and moisture, could it be fouling the sensors and merely require a good clean occasionally or is it something terminal like the ABS ecu etc?
Thanks for time and any advice, ben.
