Braided brake lines help
DannyAG200
Gold Member
I've ordered some brakes lines and upon removing my old lines I've noticed i cant get the brackets off the lines.
im guessing you buy new brackets to hold the brake lines in or? my lines are from prosport.
any help would be good
cheers
if its the fronts then some are supplied with p-clips to hold in place - but be careful as if they are not positoned correctly can rub on wheels
Ktec (HEL) are only ones that work as use the standard brackets.
the goodridge ones are pants , they move in the P clips. Mine rubbed on is side of the alloys. Very dangours!!!
