Boring, boring recaro post again.....
Tissue paper-like recaro cloth got two holes coming through...Guess where?? Divers side bolsters!!!! Any idea about how I get seat repaired? May takes seats out and have more hardy material put into side panels on both seats? Don't want leather...too expensive.
Have you got a quote for half leather? From what I have heard its not too expensive.
I would get them done in a different material but you would obviously need to do both sides.
I would have thought the other option would be to speak to someone in the know about buying a replacement base, Twingogeekeo should be able to help with that.
The bases look to be interchangeable, the fasten with 4 bolts underneath, so if you swapped both seats over you'd have fresh material to wear away :wink:
There was a 200 replacement base on ebay recently.
Only trouble would be that Litcy's interior will be the silver finish, same as mine, rather than the yellow one from the 200's. As I say Twingo should be able to help if the OP hasn't sorted it out another way :smile:
