Blistein B14 aftermarket spring
Hello,
Anyone know if there is an aftermarket company offering stiffer spring for the B14?
I want some more "slalom/autoX" focus spring.... B14 OEM spring are to soft with sticky tires
Where are you based? In the UK I've used Faulkners for custom springs - https://dfaulknersprings.com/
There are no off the shelf options for the b14s available, and the issue you'd have is the dampers would no longer be matched if you simply changed to stiffer springs. You'd be better off changing to yellowpeed or gaz gold coilovers.
I'm in french Polynesia ...
Yeah that's the issue with B14 as well, not damper adjustable....
I will have a look at Gas Gold or Yellow Speed, never heard?!
I see BC Racing is doing BR series as well in 10kg/mm front and 7kg/mm rear.
Why not considering B16?
more options for spring rate and I'm sure PMS can assist you in getting the right choice for AutoX
Have the B14 on it since 2017, I was thinking I could re used them :tongueout:
My Clio is now my fun car for AutoX/Slalom.
Car is basically stock except bolt on and empty.
Trying to be cost efficient as the car only do 60-80km per year of racing and is not driven except for commuting to race site.
