Belt but which one?
Hi folks I'm getting slightly worried about the car. Lately its been zero or -2 outside. When I start the car its silent however when I rev to around 1,300 there is a high pitch squeel which does not sound healthy. This continues to about 1,900 rpm and then disappears (either becuase I cant hear it or its fully disappeared). When I come off the accelerator I can hear it as it passes from 1,900 to 1,300.. now I though it might be an air leak but i'm assuming its the belts? Is this normal? I'm worried because the car is at 62,000 miles and is due its cam belt change in 6 months time.. are there any reports of these letting go early? Should I get it checked or is it OK to leave it until replacement of the cam belt?
not heard of any belts going to be honest
if you know what your doing take the auxillary belt off and see if it stops the noise
just had the lot done on my :001_rolleyes: and for the sake of 6months might be worth doing it early if the belt is worn (aux belt kits are about £50 from renault)
Had mine changed couple of months ago and it was the aux belt doing the squealing
