just had a look at them and had a mess with the adjustment in each light. lowered them down to what i fort was the correct height, marked the height on the garage door, took it out for a spin, sat behind a car and it looked to low, pulled it back on the drive at the same point, the level is alot lower then the mark, so i asume that auto level as dropped them down, so again adjusted then back upto the mark (same distance i took off in the first place) turned me lights on and off and it still comes up to the mark, wenr for a drive come back and still on the mark.
my only guesse is that the lowering has confused the autolevel and it sometime work, or its a renault and it does it anyway.
the passenager headlight has a different shaped lense that aims the light wider toward the kerb than the driver, to stop dazzling on coming drivers
