Are these the correct fitting Brakes
Front
Brake System Brembo
Height [mm] 70,6
Thickness [mm] 15,3
Wear Warning Contact Not prepared for wear indicator
Width [mm] 124,8
WVA Number 24162
Rear
Brake System Lucas
Height [mm] 53
Supplementary Article/Supplementary Info 2 with brake caliper screws
Thickness [mm] 16,2
Wear Warning Contact Excl. wear warning contact
Width [mm] 87
WVA Number 23554
Need to get these sorted the weekend as the rear is low, fast response would Appreciated
Front
Brake System Brembo
Height [mm] 70,6
Thickness [mm] 15,3
Width [mm] 124,8
WVA Number 24162
Rear
Brake System Lucas
Height [mm] 53
Thickness [mm] 16,2
Width [mm] 87
WVA Number 23554
Are they pad specs?
Rear discs are 300mmx10mm
be better with pad shape outline rather than a bit of pad technical data!
plenty of places get the 197 and the 2.0vvt clio mixed up brake wise
have you tried mr twingogeeko......probably be cheaper and guaranteed to fit o/e spec
