matt9566
After seeing this the other day I also downloaded the app and tested it out. With the phone mounted in the front of the car, it registered around 75 db whilst cruising at 70mph on a flat motorway, rising to 81 db when accelerating. Going uphill on the motorway is almost at a constant 80 db. Just pulling away normally around town and going through the rev range/gears, it registers up to 80 db. It would be interesting for other Akra owners to download the app and see what their's registers at as I think this is excessive.
Yeah that does sound as though it's quieter than mine. Mine is a late 2011 model which I believe will have the later gearbox?
The car is currently in the garage having the swivel joint done so I will ask the guy to check the manifold whilst it's up on the ramp. I can't see anything in the service history to suggest that it's had a replacement manifold though.
Which app did you download and where did you put your phone ? If I remember I'll test mine out on my way home from work.
Yes yours will have the later gearbox with the longer ratios (I think)
Definitely get your mechanic to check the manifold, maybe even get a photo then we can have a look ?
