Its in the front passenger side footwell up behind the the centre consol on the engine bulkhead in the heater air box.
Push the pasenger seat right back then lay in car and look up behind centre consol(a torch comes in handy at this point.) There is a small plastic tag on the filter at the bottom(see diagram below) ,when removing use the tag to pull the filter out with pliars.
Then just push the new one in using your hand to guide under heater pipes.Takes 2 mins.
BTW the filter sits verticaly not horizontal as shown here.Tag to the bottom .
The pollen /cabin filter really helps my hayfever with the recirculation on and air con on 15 which on mine is blowing out cold air at 4.5 degrees c
