IF you HAVE the necessary amount of gas in the system when you switch ON your AC you should hear the compressor plug in (and you should feel the rev changing) - if that doesn't happen, then there's some problem with the compressor.
BUT - if the compressor does turn on when you switch your AC on then it could be a valve in the compressor (I had also this problem because the one in the new/used compressor that I bought wasn't good
And the third but not the last thing - the pressure regulator (presostat in Croatian) can also be the source of failure. It's the cheapest solution - maybe if you start with that and work your way up?
