Adjusting Handbrake?
Hey guys,
I've just put new discs and pads on my car and the handbrake now needs adjusting, how would I do this?
Thanks in advance :smiley:
There are a set of bolts on the 2 rear calipers pull the cable slightly and tighten the bolt to increase the tension. I think thats it anyway mate
Hmm ok thanks mate. I did have a look to see if there was anything like that when I had the wheel off but couldn't see anything. I'll have another look :smile: thanks
handbrake adjuster is in the centre console....
two screws at the back so you can lift it up and get at the single 10mm
nut to take up the slack located on the handbrake lever
always makes sure you pump the brake pedal and work the handbrake to make sure the auto adjusters take any adjustment up before adjusting the cable
