Adjusting door
Dropped? There's 2 bolts for adjustment on the inside. Mines dropped so badly I need to fabricate a spacer to sit between the hinge and door to push it up.
Mines has done it too, owner before never really noticed so doors and sill is all scuffed from having to force it shut. Need it done soon!
i am prety sure that mine has dropped a little as it always feels like it is rubbing on the sill. any help would be appreciated
I'm sure there's a guide on here.
But from memory, loosen the bolts on the lower inside hinge. Use a jack and something between the jack and door to lift the door and retighten.
Mine makes a knock sound sometimes when I open it too quickly...I guess they all drop a little over time. Thanks for the info Rogue.
