Hello there guys !
Got a Clio 200 on a 59 plate and having a (slightly)big issue, having paid for a local garage to diagnose my cars fault (read charge me 40 quid to get a fault code ) then not have a clue how to fix it ! I'm trying to avoid the local stealer
Symptoms : ESP light on , ABS light on , spanner on , STOP light on , handbrake warning light on .
History: for a short amount of time poss a week after changing battery the above lights came on and for the lock to lock ESP trick worked and the lights turned off then lights came on and stayed on .
Fault : abs doesn't work and before the lights came on for the last time the ESP had just kicked in and the dreaded beep beep and lights.
Fault codes returned were brake circuit fault and esp circuit fault.
I have tried , testing brake sensor (well removed pulled the plunger out and replaced and it clicked back) topped up brake fluid , is there anything I have missed ? An little tricks or possible diag I could do myself
Thanks in advance guys !
