A/C repair
and as stated if the pressure drops the system will not work as the gas also carries lubricating oil for the compressor internals on the end of the condensor (small radiator in front of main one) has a pressure switch to monitor the system pressure - so if this is faulty (ie pressure ok) could cause non working air con
Reactions: Big Ben
Ben I've got a spare condenser if you are interested. I bought it when I realised mine was leaking but it was eventually covered by warranty so it was replaced with a new one.
Sent from my D6603 using Tapatalk
PM sent mate
