Dutch_197
I had some starting issues which I fixed:
TDC sensor for OE, NGK plugs and Valeo green top coils, removed KN filter back to OE Renault.
Did an ECU reset. The car starts and runs super. Idle is pretty much stable.
Like a girlfriend, some days better than others, but generaly OK.
But I keep having this intermittent hesitation at 2-2.5K rpm, Engine holds back, starts to "crackle" like it is chocking.
This is so intermittent that I cannot really judge when it happens but it looks like : doing normal driving around 40mph, stop, take off normally 1 into 2nd gear then from 2-3K rev.. other gears are fine. There is no MIL, no codes, checked the O2 banks and these the graphs are just perfect. The only mod left is the AKRA exhaust.
Any thoughts?
Any thoughts?
