200 Diffuser to a 197 (Difficaulty)
i would say that the heat sheilds are the same, as the exhaust back box is the same minus th different tailpipe ( round straight cut rather the slash cut), so at a guess i would say you would need to modify your tail pipes in order to fit
When you guys say modify the tail pipes, do you mean "saw them to fit", basically?
because the 200 tailpipes are slightly longer i think, cut down the tail pipe and get made some slip on tailpipes of same design as the 200
"borderline helpful" mmmm.................
no mods to the heatshield
its easier if the 197 exhaust is standard as the slash cut pipes are smaller getting one to fit isnt that difficult if standard :thumbup:
Did you post this on the RS Forum? There is an identical thread there...
As above, the pipes will likely need extending as I think they will be a little short.
