Hi, What is involved in replacing (upgrade) the door and rear side panel speakers, ie do you have to remove the whole panels or do the speaker grills remove and allow access to replace, also is there any reference for the direct replacement Pioneer speakers front and rear many thanks.
I have pioneer TS-Q131C for the front, theses are a direct replacment for the front and come with seperate tweeters for the grills on the dash. Just check as i dont think the cup models have tweeters.
At the rear i have the pioneer TS-E1320i. When fitting thes the two lugs need to cut off and needs to be wired up.
The sound is better in the car, think changing the headunit will make a bigger difference. I didnt wasnt to do this as i wannted to keep the crontrols by the wheel.
