19mm Ktec spacers, H&R springs, and rough labour estimate
Jordanfaf
Winner - POTM November 2017, January 2018
About to order H&R springs and Ktec 19mm spacers for the 197, anyone els running this setup? Wondering if you get any rubbing on arches and if the wheels are within the body of the car still (Need to pass NCT)
Also if anyone has had a ball joint done what did you pay for labour, getting a quote of 300 euro labour for ball joint, tie rod end and springs install, does this sound about right?
not that set-up personally, but you won't get rubbing nor will the wheels stick out. there are people running et45 wheels with no rubbing on coilovers so you'll be fine.
is the 300 for labour only? ball joint is around £160 fitted, maybe an hour for the tie rod and 2 hours for the springs?
Yea, 300 euro labour only for springs, ball joint, and tie rod end. From a trusted Indie
Renault Ireland wanted 280 for ball joint part and labour only so i thought it was a decent deal
