197 turbo questions? ? ?
Discussion in 'FI' started by andyc5, Mar 12, 2017.
  1. andyc5
    andyc5
    7
    Car:
    C63 amg
    So I have recently bought yet another clio.
    A 197 ly f1. The car is perfect just what I was after though I would like to turbo it.
    I have had a high boost 182 so know what to expect.
    May main reason for the post is I don't know what route to go down, do I fit a megane engine or turbo the standard? I'm after high boost around the 320 mark would be ideal.
    Interested to know people's thoughts and how others have done theirs. Thanks in advance
  2. Dystant
    Dystant Detailing Dale Paid Member
    1,577
    Manchester
    Car:
    Clio 200 CUP
    @Sean197 @Pav probably be able to give some imput here :smile:
    There are others but can't remember who else off the top of my head.
    Sean197 and Pav like this.
  3. DS197
    DS197 POTM Winner - June 2017 Paid Member
    1,635
    Car:
    Clio 197
    If you're looking at that sort of power, your best bet is a megane 250 engine. The standard 197 engine is only worth turboing if it's going to be fully forged. However a Megane conversion will be cheaper.
    sevenfourate likes this.
  4. Sean197
    Sean197 RIP Albi :( Moderator
    3,498
    Fife, Scotland
    Car:
    Albi 197T - RIP, MK7 Golf GTD Sports Wagon
    If you want 320 bhp you'll need to upgrade your fuel pump, standard clio pump is good for 310bhp with 630cc injectors.
    With a fuel pump and 250 engine (with 630cc injectors) you can do 320bhp and 360lb/ft all day long, to hit those figures with an f4r or 225 engine you'll need to go forged bottom end.
  5. andyc5
    andyc5
    7
    Car:
    C63 amg
    Thanks for your reply how capable is the 225 edu and turbo then or the 250 turbo
  6. Sean197
    3,498
    Fife, Scotland
    Car:
    I put the 250 turbo on my 225 engine and the difference is night and day. Holds boost much longer but spool up is the same. 630cc injectors are a must as standards max out at around 270bhp. Standard bottom end goes bang around 300lbft torque (rods bend). 225 ecu is fine, just needs recoded with the clio immobiliser and it's good to go.
  7. andyc5
    andyc5
    7
    Car:
    C63 amg
    So maybe best to put a 225 engine in but forge bottom end. What power is yours
  8. Sean197
    3,498
    Fife, Scotland
    Car:
    I'm running a conservative 278bhp and 285 lb-ft torque with 630cc injectors, 250 turbo and an rs tuning remap. My exhaust is holding it back though, if I fit a 3" system it would run 300bhp all day long.
  9. Pav
    Pav Moderator
    11,645
    Manchester
    Car:
    albi blue 197 with boost
    sorry a bit late to the party..Sean has answered most of your q's..well ideally you wanna go with a 250 engine and turbo..for a 320 mark you would need to forge some parts and as above upgrade you fueling..not sure what else needs changing etc but you are looking a few pennies to be spent :sunglasses:
    Dystant likes this.
  10. Woznaldo
    Woznaldo Paid Member
    14
    Car:
    RS200 Cup
    I've read a lot of threads on boosting your 197/200 and they all come to same conclusion, but the reasoning seems to be 'bang for buck' based and not necessarily on outright pros and cons. With that in mind I'd like to know what the differences are in the different engines.
    Cranks: Are these the same between 197, 200, 250, 265, 275 etc? If not, which are stronger? Are they all forged?
    Con Rods: same questions
    Pistons: this one is more obvious as the comp ratios are different
    Exhaust Manifold: How does the 250, 265, 275 manifold compare to the Engine Dynamics log manifold?
    Trasmission: I know of the 197/200 syncro issues, but they seem to be strong, is the Meg box better? Probably worth it if it has an LSD?
    ECU: Can the Siemens S3000 from the 197/200 be configured for boost (I believe moderate boost can be done)? Can I plug in a Meg ECU?
    Woz
  • Share This Page
