Hi all,
Bought what I thought was a clean 197 in December, had the Cambelt done at Renault Bristol, where they did a health check and did not seem to catch this...
Whilst doing a full service myself (Oils, filter, spark plugs and Thermostat), I noticed when taking the passenger front wheel off, that the following bolt was missing its Nut.:
(Back of the Hub, that looks like it pinches the strut?)
I tried to place a M12 x 1.25 nut on the bolt, but soon found the reason it is missing, is because the threads are shot!
So I started to try and remove the bolt itself, which does turn, with a huge breaker bar, but it is TIGHT and does not want to punch out (Which is probably what the previous owner did, trying to remove the bolt, which ruined the threads).
This does seem solid, but I have OCD and obviously want to correct it.
My question is, would this concern you?
Does the bolt 'pinch' the hub around the strut/damper, or does it go through a 'tab' on the strut/damper, which would stop this "flying out".
Im telling myself that Gravity would stop this happening and in the pics, the car is jacked up, so the hub is at its lowest and does not seem to let the strut/damper out.
Anyone got advice on how to remove the bolt, so i can insert a new bolt with nut?
Thanks for the help
Thanks for the help
