Hello all,
I’ve recently had issues with my hazard lights flashing and found that the scuttle tray drainage holes were blocked, causing it to be completely flooded and drain into the passenger footwell.
I’ve checked over the multi connector and it looks like one of the pins had some erosion and is no longer on the male connector, but got stuck in the female connection side and melted the plastic around it. Basically now both sides are knackered.
I’m guessing my best option is to get replacement green connectors and re-wire? If so, do you know where I can get the connectors from?
It’s the wire into 64C that’s broken and also notice the immobiliser wiring had corroded as that had come out too.
any help or suggestions are appreciated!
Thanks
Ryan
Thanks
Ryan
