Cutting out at high revs.
VeiRoNv2
Hi,I have an issue with my Clio where it cuts out at high revs,the engine light comes on for a few seconds and the traction light as well.
If I rev it slowly it doesn't typically do it,I made a video below while parked up but it also does it almost all of the time when driving too, usually from 3rd gear up,I just replaced the crank sensor and that didn't fix it, pretty much replaced all of the sensors In the last months, only left pre cat lambda and fuel pump now.
Spark plugs and the 4 coil packs are only a few months old.
This started happening maybe a few months back where I noticed the engine cutting out on the motorway just a few times but only yesterday got much worse.
Also no fault codes are showing which is really annoying.
I cant even use my diagnostic on data stream because when this happens it cuts the connection and I loose all the values and need to go trough the connection process from the start.
Hoping that someone could point me in the right direction, thank you
I replaced the alternator about 2 months ago with a Starline one from euro car parts.
I noticed when this happens the alternator stops charging and it takes a few moments for it to go back to 14volts but it does feel like the engine shuts off for a second when the engine light comes on,so thought it will be this to cause the effect and not the alternator to be the cause,I still have the original alternator that I could try fitting back.
Thanks I thought so,I will surely check all the connections in the engine bay especially the grounds and report back.
Have you looked at the throttle body and pedal connections and the plug to the ECU? From memory I think the engine will cut out like this if the ECU thinks it has lost connection with either.
Reactions: VeiRoNv2
Is this supposed to be wide open throttle? lol,it says full and 86% on my diag but the throttle body doesn't open anymore than this,this is just with the ignition on.
Thank you that would be great,I know it won't open all the way, just not sure what almost 90% is supposed to look like.
I replaced the alternator today no change but I finally have a fault code.
So ordred an used throttle body,it also feels down on power,quite sure there is a fault within the throttle body.
That's great thanks, mine is fucked then lol, doesn't open anywhere near that much, would also explain the power loss,thanks turkie.
I have checked all the pins from the throttle body to the ecu following this diagram,everything checks out as per diagrams,all the resistances and voltage are correct so supposedly the wiring is not at fault,next I will replace the accelerator pedal potentiometer because I dont really know what to do.
Strangely enough I have tested the thottle body on the bench with PIN 3 and 5 and it certainly opens all the way same as turkie video.
Okay I found somebody that was breaking a Clio 197 and we swapped over the following parts: different coilpacks all 4,another uch unit,another throttle body even tough i just changed it,throttle pedal accelarator unit and battery none of this fixed the issue,still cutting out at full throttle,at this point i will message EFI which mapped my ecu and if there might been a problem with the map.
Reactions: RSRowe and Foxspeed
