Intake manifold sensor
Inlet manifold pressure sensor. Where is it on a 197. Got a fault code onit. Abnormal voltage and signal incoherent. Anyone help....?
Let it idle for about a minute until the revs have settled before you start to drive. Besides that full throttle input at low revs can also cause kangarooing under certain circumstances.
Like said an aftermarket exhaust can exaggerate the problem.
