Which wires relate to radio stalk controls?
Hi guys.
Any help would be welcome on this one!
I have a parrot kit in my car and have also bought a multicomm adapter from parrot, this basically does away with the parrot controls and uses the radio controls by the wheel so everything will be OEM looking.
Ive got everything installed apart from two wires which need to be connected to the wires coming from the stalk controls to the back on the head unit these must receive the signal from the stalk controls and send them to the parrot.
Does anyone know which wires these are? I am pretty sure its two of the ones in the smaller yellow connector in the back of the HU because if you disconnect only that then you loose the dash display AND the stalk controls but the radio still works.
Cost £120 for all parts so not bad for a totally OEM setup if i can sort this hurdle.
Thanks for any help.
