am I missing something? K tec want six grand to do it. As some may no have started collecting stuff. So engine, gearbox, intercooler etc drive shafts. So doing it yourself can't be more than 2000?
The only guy I would trust is Andrew pm.me and I'll send you his number budam I missing something? K tec want six grand to do it. As some may no have started collecting stuff. So engine, gearbox, intercooler etc drive shafts. So doing it yourself can't be more than 2000?
I don't see it's anymore difficult than a straight swap. yes I no you have to do camber, clutch etc but mechanically it's a straight swap? it's just wiring and inter coolerMost of the cost would be labour, and i'm guessing Ktec's hourly rates aren't exactly cheap either
Cambelt!I don't see it's anymore difficult than a straight swap. yes I no you have to do camber, clutch etc but mechanically it's a straight swap? it's just wiring and inter cooler
That's what I thought too, but with the engine already being out the car, it should be much easier and quicker to change the cambelt over.Cambelt!
@Siliconsteve nut case just from my little experience the Meg MK3 chassis is a lot more stable at 120/140 mph plus over the MK3 clio budTell the girlfriend!
Have just bought a engine turbo loom and gearbox which I no can't use for 300. inter cooler kit 300. cambelt clutch etc probably 500 . do I need to change big end bolts? planning to run 250 horses6 grand is a piss take. A lot of the money, aside from the cost of the engine, goes on the smaller things like pipework, heat wrap and all the niggly little fixings etc. Soon adds up to a good few hundred quid. My R26r clutch and single mass flywheel was over £600, then there's the exhaust bits and pieces. Soon adds up!
Couldn't agree more . I've set a six month target to collect everything and check shells etc, replace head gasket etc. Only when have everything and I'm happy will I start it. Sometimes doing something yourself is better because you no it's been doneIt's the same old story though, there's doing it and doing it properly. Seen plenty of conversions done cheap and then go wrong as soon as they're running. People chucking a high mileage Meg engine in without even checking it over and just expecting it to give no issues kicking it's teeth in everyday. As been said, clutch and flywheel is £600+, new cambelt and aux bits inc water pump £220, spark plugs and fluids at a minimum so that's £1000 on top of your engine, exhaust £500. Plenty of gaskets/seals I'd want to do before putting the engine back in as well. My conversion probably owes me £5k with R26 box and loads of new parts like driveshafts etc.
Russ
Russ
This is what I figured. I had a low mileage Clio 200 and a Megane 225 with 100,000 miles on it. That'll never do.
Engine was sent away and machined. Its now fully rebuilt with new forged parts. Anything that came off was replaced with new items. Turbo binned for a new 250 turbo, intercooler binned for an Airtec one, injectors binned for new bigger ones. New waterpump, belts seals, gaskets, pipes etc. Topped off with an R26 box with Gripper diff. I'm still short of a bloody exhaust system.
It's a this point when I have to question my sanity and wonder what the hell I'm doing. I tell people it cost less than it actually has so far as I'm ashamed to tell them the real cost lol. When it was started, in March, I knew I wanted a decent build, I wanted it done properly and once only but it spiraled out of control tbh.
Suppose at the end of the day, I've got a 0 mile engine and box that I can give actual hell to (that's what I'm going to keep telling myself anyway)
Where's everyone gone? | Clio General Chat | 2 | |
Where's the best place to get REAR disc and pads?? | Suspension, Brakes & Steering | 5 | |
Where's good to buy a decent laptop online? | Latest Technology | 12 | |
| L | Where's the great cars gone..... | Other Marques | 11 | |
Where's the fuse boxes | Engine, Gearbox, Exhaust and Air Intake | 4 |
