URGENT: How do you remove the levelling motor
I've never done it on the Clio, however they usual twist a quarter of a turn then pull out don't they?
They just twist out with a quarter turn, then you have to remove the ball joint from its housing. Tilt the motor upwards and it should come free.
Cheers. It appears as though the one i bought from eurocarparts are manual adjust only :/
Take out the manual adjusters and replace them with your motors. They will still work fine. I've done this my self in the past weeks. If you get stuck pm me and I'll see if I can help.
Here's my 200 with the ECP projector lights installed.
All sorted now, cheers. The lights are going back as the inside of one of them is damaged. I'll try another time!
