possibly one of the most underated tyres going in my view!
I had them on my 172 and have just put 2 on the front of my 197 to try them..if they don't measure up then they get changed with the rears for a full set of Conti 5's in time.
FK452's almost same spec as the conti 3's but slightly better speed rating on the Falkens.
after the fit i did a few miles on straights and twists to get home not pushing too hard till they are scrubbed in..
But first impressions are they are fantastic great feed back from the tyres, smooth ride everything you need obviously when they are scrubbed in i will need to test them if you know what i mean :blink:
But first thing i noticed over the conti 3's was they warm up quicker and they don't mind wet roads...
Falken PR
''FK452 truly defines the ultra high performance tire. Falken’s optimal performance FK452 is available in a wide array of diameters, 16” – 24” and staggered widths, making it versatile and resourceful. Five linear ribs and three-dimensional rounded tread blocks offer precise handling response. With a new silica compound and multi-angled grooves, grip is significantly improved in the wet, while tire wear resistance is kept to a minimum. FK452 features the latest developments in noise absorption technology due to phase-shifted random pitch variation, while handling response and high-speed stability are improved. FK452 also boasts a reinforced steel bead filler and a dual tread compound, enabling excellent handling and quick response, particularly for larger diameter applications. ''
Just thought i would share this with you
~H~
Falken PR
~H~
