Hi, does anybody happen to know what the differential bearing preload should be set to? (TL4 Clio 197/200 gearbox)
I'm replacing the standard diff with a gripper diff, and fitting new bearings.
None of the renault literature I can find gives a bearing preload setting.
The closest I can find is guidance for a similar gearbox on another car, which specifies 10thou (0.25mm) - but that seems a lot to me.
Grateful for any help.
Thanks.
Thanks.
