Throttle pedal vibration
Hey guys,
My 197 was in for a exhaust manifold replacement, but since it got back I have a quite heavy vibration in the throttle pedal from around 3000 to 5000 rpm. Any idea what might cause this?
Hmm, not sure what you mean with lower mount...? There were a few things replaced though:
- exhaust manifold
- all engine mounts
- lower ball joint
- new front shocks
Sorry, didn't check what I wrote!
The new engine mounts will be causing the vibration. Give them a few hundred miles to bed in and you should be fine.
For future reference :smile:
I've recently mounted an upgraded torque link and the vibration in the throttle became even worse. I've thought I had changed all engine mounts by now, but seems there's also one near the timing belt. Guess what mount caused the vibration...
And on a side note, this is the new torque link:
What an massive improvement!!
Removing the silly trumpet next to the motor will also result in more vibrations below 4000rpm, but in a good way! :wink:
