Flyingfish
I’m guessing the answer is going to be hi and get it plugged in and diagnosed but I’ve just had the electrical fault pop up.
The loom has been trimmed back but it’s been fine for weeks. If you disconnect the power by the glovebox and leave it you get the esp deactivated message which if you leave the car idling stays as is with no fault pop up.
If you drive the car to clear the esp it does so as expected but after 3 minutes of driving the fault message pops up.
Everything that is left in the car works and all lights externally work, I wondered if anyone had this before and there was anything to check before getting to a garage
