i think i have a sticking rear brake caliper (common fault i think) any idea how to fix this?
lukeeddy Jan 29, 2012 #1 i think i have a sticking rear brake caliper (common fault i think) any idea how to fix this?
lukeeddy Jan 29, 2012 #3 just upgraded to a gold mebership so i can see the how to section and cleaned it up :thumbup:
N0ddie Platinum Member Jan 29, 2012 #4 lukeeddy said: just upgraded to a gold mebership so i can see the how to section and cleaned it up :thumbup: Click to expand... Excellent. Our brakes are in really bad nik at the mo. will,be getting resolved on Fridayy though (330mm discs being fitted) :bounce:
lukeeddy Jan 29, 2012 #5 the pads have worn down so unevenly one is on its last legs must have been like that for a while :thumbdown:
Roy clio197.net legend Jan 29, 2012 #6 There's your problem then.have you changed them since you had it???
lukeeddy Jan 29, 2012 #7 No only done just under 30,000 miles the other side that wasn't sticking has plenty left got some brembo pads on order should be with me by Thursday
