Squeaky brakes
Bro
The embarrassing squeaky brakes are ruining my street cred
After taking the calipers off multiple times and cleaning everything up, even putting a bit of copper grease of the back of the pads and on areas that have metal contact I still get squeaky brakes after a couple weeks
Anyone got any suggestions what I can do to prevent the noise?
You could try chamfering the pads. I did that and everything you’ve done including adding a rubber shim on the rear of the pads to stop them from squealing and nothing worked.
Eventually the pads quietened down on their own (standard brembo pads).
chamfer the leading & trailing edges of the pads and if you can take off any wear lip on the disc edges
Cheers guys, I'll give your suggestions a go [emoji106]
