Sqeaking
Getting a sqeaking from the front drivers side. Took the brakes apart cleaned them, changed discs and pads, applied cooper grease where needed, bedded them in properly.
And it's still there. The noise must be coming from the brakes as when I feather the brakes whilst rolling it dissapears.
Has anyone had any issues with hub assembly? Or a similair issue?
Thanks
Which pads do you have? I get this with DS2500 pads but didn't get it with standard pads or carbone lorraines
He means chamfer on the pad material, not the backing plate. If there isn't a chamfer here then when the pad contacts the disc it can pick up on this edge and cause vibration (noise)
I'm having this problem to, with standard pads and disks.
Stripped and cleaned them? copper slip or similar on the rear of the pads etc?
Standard pads were always terrible for it for me though.....
