Service now / spanner
Status
Not open for further replies.
Funny how things prompt you but just purchased all the bits for a full service on the 197 and I now have the 'SERVICE NOW' message on and the orange 'spanner' light is lit. I'm guessing both go together as their is also a little spanner next to the message?? How do I reset them both, Renault manual isn't that helpful???
sorry should have checked
http://www.clio197.net/forum/payments.php and subscription starts from £5 but its well worth it.
here is a list of just a few of the guides on how to do things to your car.
Service
197 Service Schedule (assume 200 is same): Clicky
Engine Bay
Guide: How to change ALL the front bulbs on a 197 & 200 (including projectors): Clicky
Guide: Access standard headlight bulb passenger side: Clicky
Guide: Where is the engine bay fuse box located: Clicky
Guide: Get side light bulb holders out to fit led's: Clicky
Guide: 200 bulb change made easy: Clicky
Guide: Working the throttle body: Clicky
Guide: Clio 200 Bi Xenon retrofit: Clicky
Guide: Panel filter replacement: Clicky
Guide: Change gear box oil: Clicky
Guide: Change spark plugs: Clicky
Guide: Oil Change: Clicky
Interior
Guide: Remove Door Card / Speaker / Stop Door Handle Creaking: Clicky
Guide: How to remove seat backs for dipping/painting: Clicky
Guide: How to fit Sprintbooster Gen 2: Clicky
Guide: How To Install Renaults TunePoint: Clicky
Guide: DIY Aux for Cabasse Changer: Clicky
Guide: Replacing Cabin/Pollen filter: Clicky
Guide: Steering Wheel Removal: Clicky
Guide: Changing glove box light: Clicky
Guide: Removing Glove Box: Clicky
Guide: Rear Seat Removal: Clicky
Guide: Dash pod removal: Clicky
Guide: Changing Seats: Clicky
Bodywork
Guide: How to adjust the boot striker without removing any trim: Clicky
Guide: Where to cut the standard exhaust to remove it: Clicky
Guide: Fit a trs tow loop to a 200: Clicky
Guide: Front Diamond Removal: Clicky
Guide: Exterior handle removal: Clicky
Guide: Replace weather strips: Clicky
Guide: Removing 197 Diffuser: Clicky
Guide: Front bumper removal: Clicky
Guide: Removing Mirror Caps: Clicky
Guide: Door Bullet Removal: Clicky
Guide: Rear Tailpipe Trims: Clicky
Brakes
Guide: Strip and clean the front calipers and change pads: Clicky
Guide: Strip and clean the rear calipers: Clicky
Guide: Quick check of your brake pads: Clicky
Guide: Front pad replacement 197: Clicky
Guide: Brake Fluid Change: Clicky
Guide: Change front discs: Clicky
Guide: Change rear discs: Clicky
Guide: Painting calipers: Clicky
Electrical
Guide: Reset service light: Clicky
Mechanical
Guide: Seized Wiper / Wipers Stopped Working Cure: Clicky
Guide: Rear Lower springs/Dampers: Clicky
Forum
Guide: Applying an Avatar: Clicky
Guide: Posting pics: Clicky
Other
Guide: Jack up a 197 and place on axle stands: Clicky
its in the manual - and isn't that hard to understand....
c) Mileage before oil change/maintenance
Distance left before the next service.
There are several scenarios:
• remaining mileage less than 900 miles (1,500 km) or next service
scheduled within two months. The “oil change required soon” message is
displayed.
• mileage before service equal to0miles/km or date of service reached. The
“oil change required urgently” message is displayed when the display
selected is “mileage before oil change” accompanied by the symbol
and the warning light.
Resetting the display after service in accordance with the maintenance
program
The mileage before oil change/maintenance must only be reset after a
service which conforms to the recommendations in the Warranty and
Servicing booklet.
If you decide to change the oil more frequently, do not reset this data each
time the oil is changed. This prevents the replacement interval from being
exceeded for other parts included in the maintenance programme.
To reset the mileage before an oil change/service, press and hold one of the
display reset buttons for approximately 10 seconds until the display shows
the mileage permanently.
pg1.75
Status
