RS Badge Help
Ok, so I bought the Front RS Badge for the 200 yesterday.
As most of you may or may not know, the RS badge comes with an connector that folds under the bonnet for the 200.
I've got the 197, so what I was thinking was, strip the metal RS letters off from the connector, leaving me with just the RS. (Job done!)
I am going to put the badge on the front right upper grill.
BUT!
What should I stick it on with?... I'm needing something that won't come up first time I wash the car, (keep in mind it won't be going onto paint work)
Cheers in advance
Gav
you can buy just the silver letters without the backing. its on the twingo.
I left the back clip on and juat trimmed it down.
Then clipped and hot glued it to bottom grill in corner.
How did it look when I sent you the pic graeme?
I've no idea where to put them.
Black might be a good shout!..
How would I stick them on?
wouldnt have it under the diamond, if i was to put it on the back then bottom right corner.
Or on the front either passenger side grill or lower grill at the far side.
Lower front grill, in one of the corners is where I would put it!
Also Araldite (as said earlier) is going to be the best stuff to use.
