Reverse and 1st gear..
Hi all,
Just a quick question..
Just parked up at work and went to reverse, when putting it into reverse heard and felt a "clunk" noise. Seemed to reverse OK.
Then went to put it in 1st, it was rather difficult to get into gear. So i sat there and tried to replicate the fault... Happened a few few but not always...
I presume this is normal for these gearboxes?
Matt
Its normal take your foot off the clutch put it back in and select a different gear (4th works well) then select the actual gear you want... :worried: sheeeyite gear box's
