Renault part numbers?
TB Rich
Hi,
Does anyone have access to a system to get Renault part numbers?
I am compliling a small list of part numbers to compare standard vs Renault Sport parts, will give an idea of whats achieveable with various stock items.
So for example, from Cup Racer to Maxi Evo - they all use the same throttle body - so if the standard item turns out to be the same then I would conclude all this talk of 64mm TB's etc to be a waste.
Whereas with injectors, Maxi and Maxi Evo both use bigger injectors, so for a genuine 230bhp+ I conclude these need swapping from stock. etc etc
Interesting to see they all use the same Inlet and Exhaust Valves too, good news for knowing the head just needs porting.
Cheers,
StandardCup RacerR3 Access
R3 Maxi (230cv)R3 Maxi Evo (250cv)
Head
77 11 160 276
77 11 162 652 (late?)
77 11 160 27677 11 160 27677 11 162 554
Inlet Valve77 11 155 37577 11 155 37577 11 155 37577 11 155 375
Exhaust Valve77 11 155 37777 11 155 37777 11 155 37777 11 155 377
Inlet Cam77 11 160 27977 11 162 39477 11 160 67577 11 162 502
Exhaust Cam77 11 160 28077 11 160 28077 11 160 67677 11 162 503
Piston77 11 160 270 (B)
77 11 160 448 (C)
77 11 160 270 (B)
77 11 160 448 (C)
77 11 160 67877 11 162 507
Rod77 11 160 27277 11 160 27277 11 160 27277 11 162 506
Rod Bolt77 11 126 62482 00 425 460
77 11 126 624 (Option)
82 00 425 460
77 11 126 624
Crank77 11 160 26977 11 160 26977 11 160 26977 11 162 505
Flywheel77 11 162 65177 11 162 430 (Flywheel)
77 11 162 519 (Flywheel+Assembly)
77 11 162 519
Inlet Manifold (Lower)77 11 160 32877 11 160 32877 11 160 32877 11 160 328
Inlet Manifold (Upper)77 11 160 28677 11 160 71777 11 160 71777 11 160 717
Throttle Body77 11 160 24977 11 160 24977 11 160 24977 11 160 249
Injectors77 11 160 28177 11 160 28177 11 160 68077 11 160 680
Airbox82 00 199 158 (Box)
77 11 160 218 (Hose)
77 11 158 636 (Filter)
77 11 160 217 (Support)
77 01 407 069 (Clip)
77 01 407 070 (Clip)
82 00 199 158 (Box)
82 00 199 158 (Box)
77 11 162 516
77 11 162 487
77 11 162 495
77 11 156 647
77 03 083 402 (x2)
77 11 162 494
Exhaust Manifold77 11 160 13077 11 160 13077 11 160 646 (Headers)
77 11 160 647 (Y Pipe)
Exhaust System77 11 160 987 (System)
77 11 160 990 (Tail pipe)
77 11 160 792 (System)
77 11 162 472 (Tail pipe)
