Rear pads and discs
Big Ben
Loves to rag the VAG!
Time for new pads and discs on rear.
Would normally go genuine Renault and dearest Ferodo pad available. Difficult to get genuine atm. Any experiences good or bad of alternatives welcome.
I am running a bit more power than standard so not looking for anything budget grade
edit: currently using Winmax W3 which destroy wheels so not using them again. Have used ds2500 which were ok
I’ve got a set of brembo drilled on the rear which are decent enough with ds2500
godspeed j hooks also seem popular
Reactions: Big Ben
I run Godspeed J hook and DS2500 on the back, they don’t do much braking on the rear anyway so no need to go mental
Reactions: Big Ben
I've had Renault and Pagid discs, both were fine. M1144 pads are around £60 on eBay.
Cup cars run Yellowstuff rears, which I've also ran, but I think the Mintex's were better, and seemed to improve pedal feel (although that last part was probably all in my head)
Reactions: Big Ben
I've had Pagid discs on the rear of mine for about 5 years now and have no complaints, got a set of PBS ProTrack pads in there at the minute and again, no complaints.
Reactions: Big Ben
CLIO Mk3 - 197/200
FRONT - Renault OE Grooved Brake Discs RenaultSport Clio 197/200
7701210178
These 312mm front brake discs fit the MKIII RenaultSport Clio 197/200 all variants including Cup, Cup Packed, R27, Gordini and Raider models
REAR - Renault OE Grooved Brake Discs CW Bearings and ABS rings RenaultSport Clio 197/200
8200883862
These genuine rear brake discs fit all the MKIII RenaultSport Clios 197 and 200 cars including Cup, Cup Packed, R27, Gordini and Raider models
FRONT - Renault OE Drilled Brake Discs -Front- RenaultSport Clio 197/200
7701208843
These front drilled brake discs fit all the MK3 RenaultSport Clio 197 and 200 cars including Cup, Cup Packed, R27, Gordini and Raider models
REAR - Renault OE Drilled Brake Discs CW Bearings and ABS rings RenaultSport Clio 197/200
8200650483
These genuine rear brake discs fit all the MK3 RenaultSport Clios 197 and 200 cars including Cup, Cup Packed, R27, and Gordini models
MEGANE MK2 - 225 /230 /R26R
FONT -Renault OE Drilled Brake Discs RenaultSport Megane 225/230
7701208843
These front Renault drilled brake discs fit all MK2 RS Meganes including 225, Cup, F1, 230 R26 and R26R models
REAR - Renault OE Drilled Brake Discs CW Bearings and ABS rings RenaultSport Megane 230 (30MM BEARING)
8200650483
These rear discs are for the phase 2 230 R26 models with the 30mm bearings.
REAR - Renault OE Drilled Brake Discs CW Bearings and ABS rings RenaultSport Megane 225 (25MM BEARING)
8200443579
These rear discs are for the phase 1 225 RS Meganes which have the 25mm bearings bore size
FRONT - Renault OE Grooved Brake Discs RenaultSport Megane 225/230 R26R
7701210178
These front Renault grooved discs are factory fit on the RenaultSport Megane R26R, but will fit all MK2 RS Meganes including 225, Cup, F1, 230 R26 and models
REAR - Renault OE Grooved Brake Discs CW Bearings and ABS rings RenaultSport Megane 230 R26R (30MM BEARING)
8200883862
These are for the MK2 phase 2 RS Megane 230 R26 , R26R and DCi 175 models with the 30mm diameter bearings
MEGANE MK3 – 250 / 265
FRONT - Renault OEM Grooved Brake Discs RenaultSport Megane 250/265
402060019R
These front Renault grooved discs are factory fit on the RenaultSport Megane Cup models but will fit all MKIII RS Meganes including 250, 265, and Cup models
REAR - Renault OEM Grooved Brake Discs RenaultSport Megane 250/265
432020026R
These rear Renault grooved brake discs are factory fit on the RenaultSport Megane Cup models, but will fit all MKIII RS Meganes including 250, 265, 275, Cup, and Trophy models
FRONT - Renault OEM brake discs RenaultSport Megane 250/265
402060012R
These front Renault discs will fit all MKIII RenaultSport Meganes including 250, 265, Cup, and Trophy models - Except the 2014 RS 275 Trophy-R which had the larger 350mm front brake discs
REAR - Renault OEM brake discs RenaultSport Megane 250/265
402023273R
These rear Renault discs will fit all MKIII RenaultSport Meganes including 250, 265, 275 , Cup, and Trophy models
