How is this fitted? I thought it would just be the sticky pads but it feels quite heavily stuck on.
BenAG200 May 26, 2012 #1 How is this fitted? I thought it would just be the sticky pads but it feels quite heavily stuck on.
G Gorms May 26, 2012 #3 Mine was sticky pads but only because i asked for no screws. Best bet is to run some floss down the back in a sawing motion.
MikeDX May 26, 2012 #4 Good move. my megane was screwed and they screwed right the way through to the other side, into the boot lining
G Gorms May 26, 2012 #6 Ben197 said: Where will the screw be? Do I need to take diffuser off? Click to expand... No you will be able to see them going through the plate. If you have no screw caps or holes in the plate then get some tooth floss and try cut the sticky pads away.
BenAG200 May 26, 2012 #7 Ok cool, that's sorted. Next what's best to get for putting my new pressed metal plates on?
G Gorms May 27, 2012 #8 Sticky pads again. I changed mine yesterday and just used 2 pieces about 2 inches long at each end.
