Wanting to change from the egg look to silvatecs but can't seem to figure out how to get it off. It would take me a while to figure it out eventually but it would be easier if I just asked you guys!
Any help would be appreciated. Thank you!
Lift the tailgate, unscrew the 3 torx screws set within the black section of the light unit then pull the unit away from the car, there are some plastic lugs which hold it on the outer edge but they will pop off fairly easily.
Unclip the multi plug. Put the light lens down on a soft surface, unclip the bulb holder section by releasing the 5 clips on the back. Fit bulb.
Reverse the above to install but before you do, give the aperture a nice polish while you have the unit out.
BINGO
