quick exhuast question..
im after buying a non- resonated scorpion exhuast am i going to see a huge flat spot? or is it going to be very slight, i will be getting a remap on the car after i fit the itg induction kit but that's probably going to be a month or two after the exhaust is on?
thanks kane
Bought mine from [MENTION=1272]Fernandez[/MENTION]
Can recommend.
My cat is still in yes, I think you get a bit of a drone with the non resonated also. I can imagine if you leave the cat in you will only have a slight flat spot.
I have a decat and non-res scorpion and it's got a bad flat spot, kangaroos when cold. Remap is in order! Although it sounds the nuts!
