Next wheel question, 8.5" ŵide wheels, is it possible?
As above is it lowered? Several people run 8" rims with an offset upto et48 and that's about as close to the arch as you can get so obviously the offset would need to be lower on an 8.5j.
Your next problem would be to find a wheel that wide that comes in the Clio fitment. They're aren't many options for these cars doe to the 5x108 pcd and high offset.
so a 8.5" et45 with 215-40-18 would probably be bit close for comfort, will be going coil overs so can adjust height to suite
